AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Problem with Automatic Loading of .NET DLLs in AutoCAD Architecture
1 REPLY 1
1401 Views, 1 Reply
I created a dll and wanted to auto netload it upon launch of AutoCAD Arch.
I have used the following instructions in
http://through-the-interface.typepad.com/through_the_interface/2006/09/automatic_loadi.html
"DESCRIPTION"="AutoNetloadDLL"
"LOADCTRLS"=dword:00000002
"MANAGED"=dword:00000001
"LOADER"="C:\MyApp\bin\Release\MyApp.dll"
However, when i typed in my commands for the dll, AutoCAD displayed Unknown Command "<Command Name>". Press F1 for help.
I have tried suggestions by people comments in the above link (i.e. setting acdbmgd.dll and acmgd.dll to Copy Local = False, restarting computer) , but I have done so, and the error still persists.
I also have used the method as suggested by writing a STARTUP lisp function to auto netload the dll file in http://www.cadtutor.net/forum/showth...hlight=netload
But the same error persists.
Would like to ask if anyone has encountered the same issue before, and can enlighten me on how to solve this problem?
I have used Process Explorer to check if acad.exe has loaded the DLL, and it did!
But the commands are not found.
When I manually netload the dll by typing the netload command and selecting the dll, there is no such issue. This only occurs to me when I tried the auto methods.
The methods only works so far if I launch acad.exe through Debug mode in VS2008.
Definitely need to auto netload the DLL for my application, when AutoCAD Arch startups.
Tags (2)
1 REPLY 1
GEORGESHM
I was looking at the post from Kean too.
If you scroll down, he adds this registry section to add the command.
Just wondering if you checked it.
[HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R17.0\ACAD-5001:409\Applications\MyTestApplication\Commands]
"TST"="TST"
”Boost
