When creating a profile how do you attach a
customized pgp file to it. So when you go to a different station to work
and reload your profile it pulls the pgp file with it?
Paul
size=1>
"Apostolos T. Nacopoulos" wrote:
When creating
a profile how do you attach a customized pgp file to it. So when
you go to a different station to work and reload your profile it pulls
Paul
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
"David_W._Koch" <You
href="mailto:dkoch@ewingcole.com">dkoch@ewingcole.com> wrote in message
href="news:f168e91.1@WebX.maYIadrTaRb">news:f168e91.1@WebX.maYIadrTaRb...
can't attach a customized PGP file to a profile. What you could do is have
your standard PGP file in a given folder and your customized PGP file in
another folder. Then your standard profile would need to have the folder with
the standard PGP file earlier [higher] on the AutoCAD file search path [or not
even list the customized PGP folder] and the customized profile would need to
have the PGP folder earlier than the standard PGP folder [or not list the
standard PGP folder, but that folder probably has other files you do want to
use].
David Koch
Member of the Autodesk Discussion Forum
Moderator Program
Now does the
pgp file have to have the acad name associated with it for it to work,
"by the way I tried it and it seems to work. I used the Support File
Search Path. The next question is what is the difference between
the support File Search Path and the Working Support File Search Path?
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">"David_W._Koch"
<dkoch@ewingcole.com> wrote
in message news:f168e91.1@WebX.maYIadrTaRb...You
with the standard PGP file earlier [higher] on the AutoCAD file search
path [or not even list the customized PGP folder] and the customized profile
would need to have the PGP folder earlier than the standard PGP folder
[or not list the standard PGP folder, but that folder probably has other
files you do want to use].
David Koch
Member of the Autodesk Discussion Forum Moderator Program
Now does the
David Koch
