We have a large .NET extensions to Architecture. It consists of a set of commands, which are mostly implemented using the old COM api. (I know.. but it's an old application, and just converting it is not feasible right now)
For storing custom information in the drawing, we use schedule properties (using COM api).
In 2010 and 2012 versions, it works fine. In Architecture 2014 (RTM and SP1), the properties work fine, except for boolean properties (TrueFalse). From code it works, but whenever the user changes a boolean property using the Properties window, the value isn't persisted in the drawing.
It seems to be there's a problem with the COM api for scheduled boolean properties in 2014. I reproduced it with a simple test project, and boolean properties registered with the .NET api work fine, but boolean properties registered with the COM api don't.
Is this a known incompatibility in AutoCAD 2014, a new bug, or is something else going wrong?
Matthijs ter Woord
