AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Need help changing the Extrude command to default to [Direction]
2 REPLIES 2
475 Views, 2 Replies
Like the title says can any one help me modify the Extrude command to default to [Direction] like it used to back in 2006 seems trivial but it's killing my work flow!
2 REPLIES 2
MarySeufert
Find the ribbon panel that has the command you are frustrated with in the CUI editor. Drag and drop the order of the commands so that the option you want is dirrectly under "Primary Command".
EXPERT ELITE MEMBER
Close but not quite what I was looking for:
when you type in Exrude and select the object you get 4 choices [Direction] [Path] [Taper angle] [Expression]
I'm not sure what the default is but it used to default to (in Acad 2006) [Direction] which is what I would like it to do.
Basicaly, how can I make the Extrude command work like it did in 2006 when it was perfect and before Autodesk changed it for no reason!
”Boost
