I recently loaded AutoCAD Architecture 2008 and the menu tabs for FIle, Edit, Window etc were all missing. They are replaced with a tab that says M-Color 9.5. When i load the program with older files (from this morning) the menu tabs are there but then they disappear. How do i get them back?
Also in addition to that my toolbars are gone, but i can recover those when i have my toolbars.
Please help, I need to get this project done today and the IT guys are not in on the weekend.
Solved by djmirod. Go to Solution.
Did you ever get this problem solved? I have the same issue, but I turned my off by mistake.
I had same issues!
Resolved.
1. Missing Ribbon, Bar, Tab, Menu from top went missing I got really used to it. found a article that there is a command: RIBBON
and like magic it was back. To close is RIBBONCLOSE
2 While trying to fix I lost my Menu Bar, the text looking menu bar dissapeared.
Found a command for that too. MENUBAR set var to 1 to show set var to 0 to keep.
Best of luck
Thanks alot
i wish i can recommond your comment as the best solution
i was in a big trouble and u saved me 🙂
Thanks again
