AutoCAD Architecture Customization
Active Member
obi1knube
Message 1 of 15 (48,348 Views)
lost menu ribbon
48348 Views, 14 Replies
07-16-2010 03:02 AM
I was workingona project with autocad 2011, but i lsot the original menus, Ihave been obliged to use the costomed menu. I knew how to use Autocad 2000 and ADT 2002, I have not used them for years, and now I have become a novice. Please help!!!!!!!!!!!
David_W._Koch
Message 2 of 15 (48,339 Views)
Re: lost menu ribbon
07-16-2010 03:26 AM in reply to: obi1knube
Are you using AutoCAD Architecture 2011 or AutoCAD 2011?
What do you mean by you lost the "original" menus?  Do you have no menu at all (no ribbon)?  Or do you mean that the pull-down menus and toolbars are missing?  If the latter, they are not missing, they have been removed from the ACA.cuix, in favor of the ribbon interface.
If you used the RIBBONCLOSE command to turn off the ribbon, the RIBBON command will turn it back on.  Or, you can set the RIBBONSTATE system variable to 1.
David Koch
Active Member
obi1knube
Message 3 of 15 (48,338 Views)
07-16-2010 08:27 AM in reply to: obi1knube
Mr. David, Thank you soo much for your intrest in helping me. I am using a trial version of Autocad Architecture 2011. The problem started when I tried to revise the  tools , I accidentally changed the program.
All that i can see now are : the save icon, undo and redo icon,print icon,project navigator icon, create a new file icon and a little bit more.
How do i bring back all the tools to the window of my current file?
David_W._Koch
Message 4 of 15 (48,336 Views)
07-16-2010 09:32 AM in reply to: obi1knube
See the attached image.  Perhaps you have simply cycled the ribbon to a minimized state.  If not, try typing RIBBON at the command prompt.  If you turned the ribbon off, that will turn it back on.  If both of those fail, check the Options dialog, on the Files tab, to see what Customization File has been specified.  If that is blank, or points to a file that does not have ribbon tabs defined within it, you will not have any ribbon tabs.
David Koch
Active Member
obi1knube
Message 5 of 15 (48,331 Views)
07-16-2010 10:14 AM in reply to: David_W._Koch
You are right, thanks for you help (:, now it´s here again.
New Member
Justin_A
Message 6 of 15 (42,164 Views)
12-28-2011 11:58 AM in reply to: David_W._Koch
I have had that aproblem a few times too. But my current situation is that I lost my .cuix file that has the tabs and panels for my ribbon. Can't seem to find the right file.
New Member
azizimokhtar1984
Message 7 of 15 (33,567 Views)
01-14-2013 05:50 PM in reply to: Justin_A
Can ribbon that been used in autocad 2000 can be load in autocad civil 2010? i have problem load that ribbon. Please help.
Valued Contributor
autocad.phil
Message 8 of 15 (32,484 Views)
02-16-2013 09:29 PM in reply to: azizimokhtar1984
I just became a "I Lost My Ribbon" club member!  I reinstalled the software/suite the other day (clean/full install, including registry trimming/wipeout).  Today I signed into Autodesk 360 account and... bam.... it sent me to the bug report page.  There I was wondering what happened.  Later I started Autocad (blank file) and found my ribbon missing.  I shut down Autocad, then opened a dwg file and it was still missing.  I tried the RIBBONCLOSE, RIBBON, etc but it didn't help.  The ribbon really is there... but totally blank:smileyhappy:
There I was thinking... no wonder... some people just refuse to use ribbons but the legacy menu system lol:smileyhappy:  Here I am adventurous to use ribbons after avoiding it for many years ha ha:smileyhappy:  Anyways, while messing around I went to the top-left corner (the A icon/menu) and found/selected something like "show menu bar" and it gave something like the "File  Edit   View  Insert  Format  Tools" etc pulldown menus.  Somewhere in there was an item related to Workspace and I selected "3D Modeling".  Lo and behold... all my ribbons showed up again and it's all good!! :smileyvery-happy:
Autodesk Product Design Suite Standard 2014 with subscription to 2016 | AutoCAD WS | was ACLT 2000, ACLT 2010, PRDSS 2013 and others
New Member
fender_102
Message 9 of 15 (26,812 Views)
07-09-2013 12:01 PM in reply to: obi1knube
Hi!
I use Autocad  2014 and I cant find my ribbons. I dont have the button to cycle through the states and even when I type ribbon in the command line, it does not seem to want to open. I checked the file path in Customization file and the specified file is : C\.......\autodesk\autocad 2014\r19.1\enu\support\acad
I also tried : C\......\autodesk\aca2014\enu\support\acad and it doesn't work.
Any help would be greatly appreciated.
Thank you very much.
Member
alchimist
Message 10 of 15 (24,066 Views)
09-12-2013 06:26 AM in reply to: obi1knube
To fix this, type 'cui' to open the 'Customize User Interface' window.
Make sure you are on the customize tab (should be default)
Make sure the top left window is expanded (the Customizations in All Files window)
Scroll to the very top and right-click 'ACA' or 'ACAD'
Then select 'Reset ACA.CUIX'  or 'Reset ACAD.CUIX'
Click 'Continue' on the pop up window.
Then I had to close and re-open AutoCAD for the ribbon to reappear.
Hope this helps
Hans
