I only know LISP (not VBA, .net or other languages) and there seems to be a lot of data I don't see anymore when trying to get from entities. I need this data for some of my programs to run & without them it's like a step back instead of forward, as far as up-dating from 2007 to 2012.
Example: Using this code:
(entget (cdr (assoc 341 ed1)))
In 2007 I get this much data:
((-1 . <Entity name: -5f82a8>) (0 . "AEC_MVBLOCK_REF") (330 . <Entity name:
-119308>) (5 . "2246EB") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"DWV") (62 . 4) (6 . "ByBlock") (100 . "AecDbEntity") (102 . "{AEC_SUBOBJECT")
(300 . "AecImpMvBlockRef") (100 . "AecImpObj") (3 . "") (100 . "AecImpEnt")
(171 . 0) (100 . "AecImpGeo") (10 1978.0 5.0 -2.79484) (15 3.06154e-016 1.0
0.0) (16 -1.0 3.06154e-016 0.0) (210 0.0 0.0 1.0) (360 . <Entity name: 0>) (100
. "AecImpBlockRef") (341 . <Entity name: -5fb328>) (15 1.0 1.0 1.0) (100 .
"AecImpMvBlockRef") (102 . "{AEC_DISP_REPBLOCK_INSTANCES") (100 . "AecImpObj")
(3 . "") (100 . "AecImpArray") (90 . 1) (102 . "{AEC_SUBOBJECT") (300 .
"AecMvBlockViewInstance") (100 . "AecImpObj") (3 . "") (100 .
"AecMvBlockViewInstance") (341 . <Entity name: -116eb8>) (15 0.0 0.0 0.0) (102
. "{AEC_ATTRIBUTES") (100 . "AecImpObj") (3 . "") (100 . "AecImpArray") (90 .
0) (102 . "AEC_ATTRIBUTES}") (102 . "AEC_SUBOBJECT}") (102 .
"AEC_DISP_REPBLOCK_INSTANCES}") (102 . "AEC_SUBOBJECT}") (102 .
"{AEC_SUBOBJECT") (300 . "AecImpArray") (100 . "AecImpObj") (3 . "") (100 .
"AecOverrideCanBoundSpaces") (100 . "AecImpObj") (3 . "") (100 . "AecOverride")
(100 . "AecOverrideCanBoundSpaces") (102 . "AEC_SUBOBJECT}") (102 .
"AEC_SUBOBJECT}") (100 . "AecDbGeo") (100 . "AecDbBlockRef") (100 .
"AecDbMvBlockRef"))
In 2012 I only get this much:
((-1 . <Entity name: 7fffec466e0>) (0 . "AEC_MVBLOCK_REF") (330 . <Entity name:
7fffe21f9f0>) (5 . "1EFA36") (100 . "AcDbEntity") (67 . 0) (410 . "Model") (8 .
"DWV") (62 . 6) (6 . "ByBlock"))
Is there a way to get the rest of it? I'm not the brightest programmer, btw. Any help is appreciated!
Dan Price
yep... autodesk made the decision to take this away... cuts down on the overhead I suppose. You can do activeX in lisp...
(vlax-dump-object (vlax-ename->vla-object (car (nentsel))) t)
you can use this line of code to see what functions you can leverage from the selected object.
Thanks for the info. This is a neat tool & lists the info in the object (below) but only returns "T". Do you have any idea how I can capture the text so that I can go through it ad dig out the info I am looking for?
I REALLY appreciate the help, BTW, Thanks!
Select object: ; IAecsMember: Structural Member object.
; Property values:
; Application (RO) = #<VLA-OBJECT IAcadApplication 0000000141027198>
; BoundSpaces = 2
; ComponentsExtents = 0
; ConnectionNodes (RO) = #<VLA-OBJECT IAecsConnectionNodes 000000004240f000>
; CrossSectionExtents = 0
; Description = ""
; Document (RO) = #<VLA-OBJECT IAcadDocument 000000000b8124e0>
; EndOffset = 0.0
; EndPoint = (-775.125 86.0958 8.56461)
; Handle (RO) = "1C04C7"
; HasExtensionDictionary (RO) = 0
; Hyperlinks (RO) = #<VLA-OBJECT IAcadHyperlinks 000000004275d288>
; Justify = 5
; Layer = "DWV"
; Length = 39.4375
; Linetype = "ByBlock"
; LinetypeScale = 1.0
; Lineweight = -1
; Location = (-775.125 125.533 8.56461)
; Material = "ByLayer"
; Normal = (0.0 4.50423e-017 1.0)
; ObjectID (RO) = 44
; ObjectID32 (RO) = 44
; ObjectName (RO) = "AecsDbMember"
; OwnerID (RO) = 43
; OwnerID32 (RO) = 43
; PlotStyleName = "Color_6"
; Radius = Exception occurred
; Roll = 0.0
; Rotation = 4.71239
; ShadowDisplay = 0
; StartOffset = 0.0
; StartPoint = (-775.125 125.533 8.56461)
; Style = #<VLA-OBJECT IAecsMemberStyle 0000000004583ca0>
; StyleName = "DWV 3"
; TrueColor = #<VLA-OBJECT IAcadAcCmColor 000000004275ef00>
; Type = 0
; Visible = -1
T
