I noticed something strange in ACA 2011, I run a lisp routine for all my shortcuts etc... and I noticed in the new version my command for explode ((defun C:EX() (command "explode")) does not allow me to select mutliple objects. When I type in EX the command line reads Select Object: when I type in the command "explode" the command line reads Select Objects: (With an 'S') and I can window and select multiple options. Anyone have any ideas to what is casuing this? Its the only command so far that I noticed the issue.
