I have a question about integrating AutoCad LT with a WPF C# application.
I have a client for whom I develop a ERP application, this client uses AutoCAD LT to draw there products which the produce. The use main-drawings for there products, different customers order this products whith different sizes.
The client has ask me if its possible to integrate and automate AutoCad with his order-process. When he makes a new order he wants to open the drawing of the product which is ordered, alter it, and save it under a different name in a particular folder.
The altering of the drawing will be done by the customer representive (CSR), the application should automatically save the drawing in a particular folder with a name which references the particular order. After that the application should priunt the drawing and then close the AutoCad instance.
So I have the following use case:
My question is, is there a API for AutoCad which I can use to implement this functionality. Or are there other ways to communicate these commands to AutoCad.
Any help would be greatly appreciated.
Marcel
