Hi there, i'm using AutoCAD Architecture 2013 on PC.
I just changed to dark (black actually) background. How do i invert the display color scheme? If I had a layer with black before, it should be displayed on white now, not grey.
Thank you in advance for your attention to this matter.
Solved by leothebuilder. Go to Solution.
When you changed you model space background color autocad does not (always) automatically invert any layer colors.
If the layer color 250 is too difficult to see you will need to change the color to something more visible on screen.
