AutoCAD Architecture Customization
BIM_Manager_Orbicon
Message 1 of 3 (365 Views)
How to make the rename-method of the Classificationtree work?
365 Views, 2 Replies
08-07-2012 01:11 AM
I need to rename some nodes in a classification tree but I keep on getting the exception.message "eInvalidInput" from the exception.source Acdbmgd.
Any suggestions?
Here is the code:
<Autodesk.AutoCAD.Runtime.
CommandMethod("RenameClassificationTreeNode")> _
PublicSub RenameClassificationTreeNode()
Dim ed AsEditor = Application.DocumentManager.MdiActiveDocument.Editor()
Dim db AsDatabase = HostApplicationServices.WorkingDatabase
Dim tr AsTransaction = db.TransactionManager.StartTransaction
Try
Dim dict AsDictionaryClassificationDefinition = NewDictionaryClassificationDefinition(db)
Dim ids AsObjectIdCollection = dict.Records
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject = tr.GetObject(id, OpenMode.ForRead, False, False)
Dim classCollDef AsClassificationDefinition = obj
If classCollDef.Name = ("AAU_SfBClassification") Then
Dim classTree AsClassificationTree = classCollDef.ClassificationTree()
                    RenameTreeNode(tr, classTree)
EndIf
Next
Catch ex AsApplicationException
            tr.Abort()
Finally
            tr.Dispose()
EndTry
EndSub
Private Sub RenameTreeNode(ByRef tr AsTransaction, ByRef node AsClassificationTree)
If node IsNothingThenExit Sub
'Here is the task: Remove paranthesis if present
IfNot (node.Id.IsNull) Then
Dim Clsfc AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForRead), Classification)
Dim OldName AsString = Clsfc.Name
If OldName.Contains("(") AndAlso OldName.Contains(")") Then
Dim Newname AsString = Replace(OldName, "(", "")
                Newname = Replace(Newname,
Try
                    node.Rename(Clsfc.ObjectId, Newname)
' THIS FAILS!!!
Catch ex AsException
                    MsgBox(ex.Message)
EndTry
EndIf
EndIf
If node.Children.Count > 0 Then
ForEach ChildTree In node.Children
                RenameTreeNode(tr, ChildTree)
Next
EndIf
EndSub
Jan Grenov
CAD Manager
Orbicon A/S
Hi Mikako
Thanks a lot for your help. I tried it out and made some minor adjustments. Then it worked out fine :-)
Here's the final code:
''  Rename classification definition tree names
CommandMethod("ACANet", "RenameClassificationDefTree", CommandFlags.Modal)> _
PublicSub RenameClassificationDefTreeNames()
''  Some basic things here
''  Start a Transaction
Try
'' get the dictionary for the classification definition,
'' and list of records in it
Dim id AsObjectId
''  loop through each classification def
ForEach id In ids
Dim obj AsObject
                obj = tr.GetObject(id,
OpenMode.ForWrite, False, False)
''  print out the name of the classification.
                ed.WriteMessage(classCollDef.Name + vbCrLf)
''  Get the tree and print it out
                RenameClassificationTree(tr, classTree,
Next
            tr.Commit()
            tr.Abort()
            MsgBox(ex.Message)
Finally
            tr.Dispose()
EndTry
EndSub
PublicSub RenameClassificationTree(ByRef tr AsTransaction, ByRef node AsClassificationTree, ByVal sIndent AsString)
Return
EndIf
'' let's get the name of the top most node.
Dim classi AsClassification = CType(tr.GetObject(node.Id, OpenMode.ForWrite), Classification)
If classi.Name.StartsWith("(") AndAlso classi.Name.Substring(3, 1) = ")" Then
Dim Newname AsString = classi.Name.Substring(1)
SelectCase Newname.Length
Case 3
                        Newname = Newname.Substring(0, 2)
Case 4
Newname = Newname.Substring(0, 2) &
"." & Newname.Substring(3)
EndSelect
                node.Rename(node.Id, Newname)
Dim s AsString = sIndent + classi.Name + "(" + node.Id.Handle.ToString + ")" + vbCrLf
                ed.WriteMessage(s)
EndIf
EndIf
'' visit childen.
'' this is a intemidiate node, go through each branch.
Dim child AsClassificationTree
            sIndent = sIndent +
ForEach child In node.Children
                RenameClassificationTree(tr, child, sIndent)
Next
EndIf
EndSub
End
Class
ADN Support Specialist
mikako.harada
Message 2 of 3 (346 Views)
Re: How to make the rename-method of the Classificationtree work?
08-12-2012 10:35 PM in reply to: BIM_Manager_Orbicon
Hi Jan,
I did not try your code, but looks like your code is written in read only mode.  If you want to modify database objects, you will need to open for write and commit transaction.
Here is a sample code that goes through the nodes and add " API" to the name of each node.  I hope this helps.
  <CommandMethod("ACANet", "RenameClassificationDefTree", CommandFlags.Modal)> _
    Dim ed AsEditor =
    Try
      Dim id AsObjectId
      ForEach id In ids
        Dim obj AsObject = tr.GetObject(id, OpenMode.ForWrite, False, False)
        RenameClassificationTree(tr, classTree, "")
        tr.Commit()
        'End If
      Next
      tr.Abort()
      System.Windows.Forms.MessageBox.Show(ex.Message)
    Finally
      tr.Dispose()
    EndTry
  EndSub
  ''  Given a top most node of a tree, traverse the tree
      Return
    EndIf
      node.Rename(node.Id, classi.Name + " API")
      ed.WriteMessage(s)
    EndIf
    '' visit childen.
      sIndent = sIndent + "  "
      Next
    EndIf
  EndSub
Mikako Harada
Developer Technical Services
Autodesk Developer Network
BIM_Manager_Orbicon
Message 3 of 3 (342 Views)
08-13-2012 01:24 AM in reply to: BIM_Manager_Orbicon
Hi Mikako
Try
Dim id AsObjectId
ForEach id In ids
Dim obj AsObject
Next
            tr.Commit()
            tr.Abort()
            MsgBox(ex.Message)
Finally
            tr.Dispose()
EndTry
EndSub
Return
EndIf
Case 3
Case 4
EndSelect
                ed.WriteMessage(s)
EndIf
EndIf
'' visit childen.
            sIndent = sIndent +
Next
EndIf
EndSub
End
Class
Jan Grenov
CAD Manager
Orbicon A/S
