AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
How to get path of clipped xref in viewport
1 REPLY 1
431 Views, 1 Reply
MEP 2008
I have a View drawing with 2 constructs xref'd into it.
This View drawing is then xref'd into the sheet and then the viewport is then resized to show only a portion of the view drawing.
In the Sheet
When my program runs the viewport has already been selected.
Using anything BUT VB how can I get the path of an xref in an Active viewport?
Currently I am getting the corners of the active viewport and using ssget "c" but it only works on some viewports.I have 2 that the clips are of smaller areas, though they still display objects, ssget "c" will not find anything in the viewport.
I can find all the xref's in the sheet, is there a way to find out what viewports they are in (working the problem backwards)?
Is there a better link between the viewport and the xref it contains that I can get?
Thanks Message was edited by: Loki
1 REPLY 1
any answers to this for ACA2012?
”Boost
