Hello everyone
I can create wall from a 3d solid by using command "wall", or "wallbodyconvert". Normally I'm sending this command by using SendStringToExecute method, but I wounder if there is a way to do this by using object operation.
I fond the Wall class in aecarchmgd.dll (Autodesk.Aec.Arch.DatabaseServices) but I have no idea how to use it. This class has a method CreateWall, but first parameter is IntPtr, and I'm not sure where should it point?
Regards
