AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
How can I access ADT/AEC objects geometry?
10 REPLIES 10
Message 1 of 11
642 Views, 10 Replies
I have to etxract the geometry (the boundery of the shape/polyline what
ever) of my ADT areas. In the interface (ActiveX) I found properties for
Location Width and others, but I need the geometric object(s).
How can I access them? I tried wether the the ADT objects supports the Block
interface (IAcadBlock), but it does not. If there is really no way to acess
the graphic, are there some work arounds somthing like giving the object an
EED and store it in a simple drawing and reread it?
PS.
Is 'space' and 'area' the same objects? In german ît is called 'Fläche', the
objects name is 'AecDbArea', but in the ActiveX there is no such object, but
a 'AecSpace' I guess this space is an area isn't it?
10 REPLIES 10
Message 2 of 11
Spaces and Areas are two separate objects in ADT3.3.
David Koch
Member of the Autodesk Discussion Forum Moderator Program
Message 3 of 11
'Declare an object for your temporary use
Dim objMy as Object
'Declare a variable for your space
Dim mySpace As AecSpace
'Choose your method of accessing spaces such as
'iterating all elements of drawing, user selection by pick, etc.
'Check that entity is really an aecspace before using it.
If TypeOf objMy Is AecSpace Then
'set object to space for operations
Set mySpace = ThisDrawing.HandletoObject(objMy.Handle)
'Clear variable not in use
Set objMy = Nothing
End if
' You now have a valid aecspace what you do with it is up to you
Richard Binning
CADD Coordinator
The Haskell Company
http://www.thehaskellco.com
"Thomas Kohler" wrote in message
news:598377CF470925B1468AB2A2FAFECB59@in.WebX.maYIadrTaRb...
Block
acess
an
> PS.
the
but
Message 4 of 11
My problem is not to get the ADT object, because I have it by iterating over
the drawing.
I should access the geometry of the area (not space like I learned). For the
area for example I should access the border Polyline/Shape or whatever a
Area is built up.
It is not a specific problem of this Area, there must be a general concept
accessing the geoumetry of AEC objects, that is not the location or a width
only, but the whole appearance like they are drawn (the geometic
promitives).
I hope I could express my problem clearer.
"Richard Binning" schrieb im Newsbeitrag
news:4B2EAA774C8BCFBD621FE177452920EB@in.WebX.maYIadrTaRb...
> Dim objMy as Object
> Set objMy = Nothing
> End if
> Richard Binning
> CADD Coordinator
> The Haskell Company
> Block
> acess
> an
> > PS.
> the
> but
Message 5 of 11
So you are attempting to gain access to the base object entities (i.e. you
want to get the lines that make up the space in plan view).
Get ready for ObjectARX
Dean McCarns
news:3665B2927661CDC7D92904C9DA051E26@in.WebX.maYIadrTaRb...
over
> the drawing.
the
> Area is built up.
width
> promitives).
> > Dim objMy as Object
> > Set objMy = Nothing
> > End if
> > Richard Binning
> > CADD Coordinator
> > The Haskell Company
what
for
> > Block
> > acess
object
> > an
> > > PS.
'Fläche',
> > the
object,
> > but
Message 6 of 11
Sorry I am not ready for ObjectARX, because I have no license for it.
I would like to use the ActiveX interface to iterate (windows would call it
enumerate) one AEC Object
to get the graphic primitives. If this is really not possible, then it must
have been a marketing decision,
because this functionality is available internally (the AECObjExplode
executable does exactly this job).
This brings me the idea to use an explode method to get the graphic
primitives.
Is there any such (explode) command/method I can use from ActiveX, giving
the AEC Object as input ?
I would like to get a block as result, so I could iterate the block easily
to get the graphic
primitives (using the item collection).
Thanks for any hints or ideas.
Thomas
PS.
How would ObjectARX solve my problem?
"DMC" schrieb im Newsbeitrag
news:33F4AAB39D955E5EABFB13CCE565DEA9@in.WebX.maYIadrTaRb...
> Dean McCarns
> over
> > the drawing.
> the
> > Area is built up.
concept
> width
> > promitives).
> > > Dim objMy as Object
> > > Set objMy = Nothing
> > > End if
> > > Richard Binning
> > > CADD Coordinator
> > > The Haskell Company
> what
> for
the
> > > Block
to
> > > acess
> object
> > > an
> > > > PS.
> 'Fläche',
> > > the
> object,
> > > but
Message 7 of 11
Thomas,
As you are discovering, ADT objects are different from standard AutoCAD
objects. The way the objects deal with graphics is a good illustration of
this difference. With a standard AutoCAD "Circle", the graphic returned are
a circle, no matter how you look at it. In the case of a door, the graphics
primitives are determined by how you are looking at the door, and what you
want the door to look like. In plan view, a simple door will be made of a
line, and an arc. In 3D, the door will be made with a body (6 faces).
In your case, you are looking for the boundary of the space or area (2
different objects, 2 different type libraries). In the current
implementation, this profile is exposed to ActiveX. However, this is on the
wish list for a future release. As suggested, with ObjectARX and the Object
Modeling Framework (OMF) this information is readly available.
Message 8 of 11
Thanks Peter for your clear answer!
Because I cannot wait until my whishes come true, I'm looking for a work
around.
I'm not eager for working with ObjectARX but I would do it, if there is no
other way.
What do you think about an 'Explode' work around? I guess the main problem
would be
to 'mark' the AEC Objects in a way I could find (identify) them again.
In the meantime I downloaded ObjectARX. I searched in the Help-Files,
but I could not get any idea how this could help me. Also the terms
Object Modeling Framework (OMF) I could not find there.
Can you tell me some other hints, how I should proceed ?
Reagards
Thomas
"Peter Funk - Autodesk, Inc" schrieb im
Newsbeitrag news:01B4A1F9F4D4F0DD82A55B2C0F407A6F@in.WebX.maYIadrTaRb...
> Thomas,
are
graphics
the
Object
> Regards,
Message 9 of 11
Thomas,
From what I get in your post you are looking for the points of a space or
area...correct? If you grab ADTcadPac (free) there is a utility to convert
spaces to plines so you can get the points.
In development I have an OMF program that grab points of various AecObjects
and allow you to add/modify them but I have some development to finish
before I ship this.
Rob Starz
| president / dreamer | director
| Stardsign cad solutions | Autodrop , llc
| 352.263.3786 | www.autodrop.net
| AEC Designer / Consultant / Developer
| Autodesk Architectural Desktop:
Tools: www.stardsign.com
Tech Support: www.stardsign.com/support.htm
Bring the power of i-drop into AutoCAD with
i-dock(www.stardsign.com/idock.htm)
news:5F2B8F09F70E8D50C124CB7BAFB82CEA@in.WebX.maYIadrTaRb...
> around.
> other way.
> would be
> Reagards
> Thomas
> > Thomas,
of
> are
> graphics
you
a
> the
> Object
> > Regards,
Message 10 of 11
I don't know if this helps but I get the points of the Roof Slab objects very
simply with
VBA. I just momentarily create an exact copy of the slab, then explode it. It
turns into 3d faces and some lines. Collect the points and then delete the
exploded objects
leaving me with the original slab and all the points.
> around.
> other way.
> would be
> Reagards
> Thomas
> > Thomas,
> are
> graphics
> the
> Object
> > Regards,
Message 11 of 11
Hi Thomas,
To use an API-equivalent of AecObjExplode, even ARX would not be
sufficient - you need full OMF which is ADT-specific C++ API based on ARX.
The only workaround would be along the lines proposed by Joel. I happen to
have such VBA code that also needs some LISP commands (since no .Explode for
ADT objects) that does roughly what you need. First, the object (AecArea in
this case) is copied, then exploded twice and finally the resulting
pimitives are extracted. This should work OK for an Area like in the code
below, but you may have some problems with e.g walls due to the wall graph
connectivity and cleanup (not sure if the wall copy would clean properly).
Anyway, this is best I can suggest and it's up to you to test all individual
objects and situations. Here's the macro:
Public Sub ExtractAecAreaCurves()
' Select Area to copy
Dim ent As AcadEntity
Dim pnt As Variant
ThisDrawing.Utility.GetEntity ent, pnt, "Select AecArea"
If ent.ObjectName <> "AecDbArea" Then
MsgBox "Not an AecArea"
Exit Sub
Dim cObjs(0 To 0) As Object
Set cObjs(0) = ent
Dim retObjs As Variant
retObjs = ThisDrawing.CopyObjects(cObjs)
'MsgBox "Copied ent = " & retObjs(0).ObjectName & "/" & retObjs(0).Handle
ThisDrawing.SetVariable "USERS1", retObjs(0).Handle
ThisDrawing.SendCommand "(command ""EXPLODE"" (handent(getvar
""USERS1"")))" & vbCr
' Exploded Result must be only one BlkRef
If ThisDrawing.ActiveSelectionSet.Count <> 1 Then
'... delete ents and some msg.
Exit Sub
Else
If ThisDrawing.ActiveSelectionSet(0).ObjectName <> "AcDbBlockReference"
Then
'... delete it and some msg.
Exit Sub
Else
Set ent = ThisDrawing.ActiveSelectionSet(0)
'MsgBox "First-Exploded ent = " & ent.ObjectName & "/" & ent.Handle
ThisDrawing.SetVariable "USERS1", ent.Handle
For Each ent In ThisDrawing.ActiveSelectionSet
MsgBox "Second-Exploded ents = " & ent.ObjectName & "/" & ent.Handle
If ent.ObjectName = "AcDbLine" Then
' get data from this line...
ElseIf ent.ObjectName = "AcDbArc" Then
' get data from this arc...
ent.Delete
Next
End Sub
Hope this helps.
Cheers,
Miro
Miroslav Schonauer
Developer Technical Services
"Joel Houtman" wrote in message
news:3DA321F0.4200D16@earthlink.net...
very
> simply with
It
> exploded objects
> > around.
no
> > other way.
problem
> > would be
> > Reagards
> > Thomas
> > > Thomas,
AutoCAD
of
returned
> > are
> > graphics
you
of a
on
> > the
> > Object
> > > Regards,
”Boost
