AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
help needed to set distance / MEASUREGEOM command to label line
2 REPLIES 2
761 Views, 2 Replies
Hello, Im in the midle of a little project and want to know if its possiable to save the info that the _MEASUREGEOM command displays when applied to measure distance or angle to the project.
I used to use a lisp script to do this but that was on my PC. Im not running autocad on my mac and it wont alow me to run the script. it loads it but then gives the error
 ; error: vl-load-com not supported on  "Mac OS X Version 10.8 (x86_64)"
when i try and apply the comand.
Does MEASUREGEOM have a built in feature to save these details to the project i.e. next to the line or shape measured?
Thanks in advance.
Bo
2 REPLIES 2
p.s. sorry if this has been covered before, i have had alook and found a couple of other routine scrips but they both both give the same error.
Have also tried the Dimension command but thats not suficiant because it doenst map angles etc.
”Boost
