Can you modify some of the properties using lisp of an aec wall style ? I have a routine that makes a "global" as I call it material, an "inner" material , that would be the aec style material pointing to the global material assigned to a wall component, and a new wall type, all with the same name, all with one click, quite the task I must say.
Everthing works except for the very last step, changing the wall component inner material definition to another one in the list. I run my routine, THEN open the wall style editor, select the component, change the material definition, then close it, this is what I want to avoid.
The routine seems simple enough, I get the entity data of aec_wall_style via a dictionary search and all the wall components of the searched wall are listed right there under the (2 . "wall-component-name"), after each name there is a 330 entitiy, that is the inner material assigned to that component. I simply do a (subst) of that 330 with one I construct using a different entity name from the aec material def library.
Then I entmod that new list, I get nil. Won't do it.
Just in case there was some sub entity that I missed or anything else I missed, I simply tried to change the name of the wall component, (2 . "old-name") to (2 . "newname"), entmodded that, nil. It won't even do that.
I wondering if there is a solution using visual lisp, any help would be appreciated.
