AutoCAD Architecture Customization
*Starz, Rob
Message 1 of 6 (258 Views)
Door Thickness
258 Views, 5 Replies
03-22-2001 11:31 PM
Ok....I think I lost it or I am in a twilight zone episode.
to get the thickness of the door leaf I would use
door.LeafWidth
door being an AecDoor
I am getting a value of Zero for all my doors.
Peter and Mark...this is part of the code I sent you back regarding the Item
issue. My VBA code was only setting the schedule to Width x Height but I
realize I forgot Thickness. So I tried the above syntax and I get 0.
I probably and looking at the wrong thing.....please say so.
Rob Starz
rob@stardsign.com
Plogv 3.0 & 2000 (plot logging) for r14 & 2000
***Enhancement Tools for Arch. Desktop *****
http://www.stardsign.com/main.htm
StarDsign cad solution
*Starz, Rob
Message 2 of 6 (258 Views)
Re: Door Thickness
03-26-2001 03:05 AM in reply to: *Starz, Rob
Rob Starz
rob@stardsign.com
*[Autodesk], Scott Arvin
Message 3 of 6 (258 Views)
Re: Door Thickness
03-26-2001 06:36 AM in reply to: *Starz, Rob
The thickness of the door leaf is the same as the thickness of the door
itself.
The LeafWidth value should only apply to Uneven door styles. Unfortunately,
the default value is set to 12 and that is what's returned whether or not it
is an uneven door.
Hope this helps.
Scott Arvin [Autodesk]
"Rob Starz" wrote in message
news:1BC5C25C182FFA70F0B805AF5B10166C@in.WebX.maYIadrTaRb...
> door.LeafWidth
Item
> Thanks
> Rob Starz
> rob@stardsign.com
*Starz, Rob
Message 4 of 6 (258 Views)
Re:
03-26-2001 07:08 AM in reply to: *Starz, Rob
Ok...so my question is how do I extract the door thickness for my schedule
3'-0"x 7'-0"x1 3/4"
I need the 1 3/4" portion. I don't see this exposed in ActiveX. Or I
maybe overlooking it.
Additionally why would the Door.Thickness return the Width. Those are 2
different variables. Length, Width, Heigth
Were does Thickness far in the 3?
Currently I have my code set up to add
& "1 3/4"" to the end of the combined width and height. When the time comes
and I have a door that is different I need to know how to change this.
Rob Starz
rob@stardsign.com
"Scott Arvin [Autodesk]" wrote in message
news:BC2C22D128D51F1DD51340627097EFC4@in.WebX.maYIadrTaRb...
> itself.
Unfortunately,
it
> is an uneven door.
> Hope this helps.
> > door.LeafWidth
> Item
I
> > Thanks
> > Rob Starz
> > rob@stardsign.com
*Autodesk\
Message 5 of 6 (258 Views)
Re:
03-26-2001 10:57 PM in reply to: *Starz, Rob
The thickness is style-based. How about this:
Sub DoorThickness()
Dim pnt As Variant
Dim obj As AcadObject
ThisDrawing.Utility.GetEntity obj, pnt, "Pick a door"
If Not TypeOf obj Is AecDoor Then
ThisDrawing.Utility.Prompt "Not a door."
Exit Sub
Dim door As AecDoor
Set door = obj
ThisDrawing.Utility.Prompt "Door thickness: " & door.Style.thickness &
vbCrLf
End Sub
Jim Paquette
Autodesk, Inc.
*Starz, Rob
Message 6 of 6 (258 Views)
Re:
03-27-2001 12:04 AM in reply to: *Starz, Rob
That did the trick. I overlooked that I could get this from the Style. It
only makes sense that it would come from there.
Thanks for the help
Rob Starz
rob@stardsign.com
"James Paquette (Autodesk)" wrote in message
news:B710187A19275A9D34AAF9EE407D8A62@in.WebX.maYIadrTaRb...
> Sub DoorThickness()
> Dim pnt As Variant
> Exit Sub
> End If
> Dim door As AecDoor
> Set door = obj
> vbCrLf
> End Sub
> Jim Paquette
> Autodesk, Inc.
Announcements
Need installation help?
