AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Distance command and text readout disappearing please help...
2 REPLIES 2
jmldg
2046 Views, 2 Replies
Hello there... having problems with one of our machines: when doing the "distance" command, typically as you go from point to point, the distance will be listed on the page next to my cursor as I go.  Then if you left click, right click, it will list the final distance down in the command window.  The machine in question no longer displays the distance on the page as you go.  This is a very useful feature for us, and although we can distance things, using the text readout in the command window takes muuuuuch longer.
I'm assuming it's just a preference issue, and I've noodled around searching for a fix, but I can't find it.  My boss, sitting next to me at the problem computer, just asked me to fix it, and I have no idea how.  Please help!
2 REPLIES 2
John.W.Mumaw
in reply to: jmldg
Is Dynamic input turned on?  Either the F12 key or the little box next to the cursor icon at the bottom left of your screen.
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
jmldg
in reply to: John.W.Mumaw
Had my settings on this forum a little screwy so didn't see your reply till now.  THANK YOU.  I knew it was something simple, but also at the same time something I never mess with.  Would have taken me eons to get there on my own.  This will make the other workers and my employer quite happy... really appreciate your response.
Liesl
”Boost
