I just migrated from 2006 to 2012... wow what a shock so far...
I was able to get my old custom tool palettes into 2012 by opening the Content Browser and idropping them. However I noticed that these palettes are not 'refreshable' like they used to be. In the Palette Properties it says *This palette is not shared from a catalog*... after doing a search of that message in these forums I found this thread: http://forums.autodesk.com/t5/AutoCAD-Architecture/Palette-not-Shared/m-p/2700196/highlight/true#M32...
I followed David's instructions:
1. Created a new Palette Group
2. Created a new palette in that Group
3. i-dropped tools from my custom catalog in the Content Browser onto that new palette.
Still there is no 'refresh' option...???
Solved by David_W_Koch. Go to Solution.
In Content Browser, at the top level, right click on your Tool Catalog and choose Properties. Near the bottom is a toggle labeled "Link items when added to workspace". Check this toggle and select OK to dismiss the Catalog Properties dialog. Now when you i-drop palettes or tools from that catalog, they should remain linked back to the catalog.
Thanks David... I haven't frequented this forum in 5 or so years but I remember you helping me way back in 2003. So thanks for stickin' around 😉
