AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
Converting lines to walls AECWALLCONVERT !!
3 REPLIES 3
1338 Views, 3 Replies
We have older drawings where we use lines as walls and we want to convert to
AECWALL. We would like to convert as is, that replace existing lines to a
wall.
Problem we are having is that intead of inserting wo parallel lines for the
wall it is inserting a rectangle, that is it is closing the sides of the
wall.
Thanks for your help.
jay.
3 REPLIES 3
Walls are parallel lines with end caps closing of the end...resulting in a
rectangle, overall. Can you explain what you are look for more.
| Rob "What did I do now?" Starz
| Stardsign cad solutions
| AEC Designer / Consultant / Developer
| Arch Desktop tools www.stardsign.com/adtcadpacx.htm
thanks for your help,
Actually I figured it out, basically there is a setting called "do not
correct", if you check it then it draws it as is.
"Rob Starz" wrote in message
news:EF644C6316A3B346E60F0B9365BF1B66@in.WebX.maYIadrTaRb...
> Thanks
What? Did I miss something? Can a double line wall be converted to a
single Aec_wall?
Matthew
”Boost
