thanks for your help,
Actually I figured it out, basically there is a setting called "do not
correct", if you check it then it draws it as is.
"Rob Starz" wrote in message
news:EF644C6316A3B346E60F0B9365BF1B66@in.WebX.maYIadrTaRb...
> Walls are parallel lines with end caps closing of the end...resulting in a
> rectangle, overall. Can you explain what you are look for more.
> Thanks
> | Rob "What did I do now?" Starz
> | Stardsign cad solutions
> | AEC Designer / Consultant / Developer
> | Arch Desktop tools www.stardsign.com/adtcadpacx.htm
