could someone give me an example how Autodesk.Aec.DatabaseServices.StreamExplode can be used to explode AEC objects using a certain DisplayConfiguration?
If I am sending a wall entity through the Stream using PushEntity I will receive a line representing the Baseline of the wall. Which is fine.
But I would like to explode the walls using a DisplayConfiguration - so my result should be four lines (boundary) and a hatch.
Is there any other Method I could use? Like Create2DSection or sth. like that?
Regards
