OK, I have been doing this for a while and now I have to go back. Unfortunately, a new project we have does not allow us to use annotative objects, so we are back to switching scale by creating several dimstyles with a varying dimscale (eg. Dim96, for 1/8", Dim48 for 1/4" etc.) Now I have created a button on the tool palette that brings in text and it allows me to set the size of the arrow by matching it to the dimstyle, but the text comes in always at the same size - 9" which is 3/32" for a 1/8" plan. The arrow changes but the text does not. I know I have to change the CANNOSCALE, but I can't seem to figure out a way of making it work so that the user will only need to switch the dimstyle from the pull down up at the top right and then be able to use a tool palette button that will bring in a text with leader with it's arrow head and text hieght matching the dimstyle's scale.
Please help. Thanks
Solved by jorgeseptien. Go to Solution.
You may want to check the text style you're using in the dimstyle.
It may be set to a fixed height of 9"
Always best to have a separate tex style for dimension text
