AutoCAD Architecture Customization
Valued Mentor
mdhutchinson
Message 1 of 3 (446 Views)
Acces Property Data this works but...
446 Views, 2 Replies
02-05-2013 02:50 PM
This code works... so long as the PropertySet is not style based.
Is there a way around this?
(setq vlaObj (vlax-ename->vla-object (car (entsel "Select a Object ")))
 acadObj    (vlax-get-acad-object)
 schedApp   (vla-getInterfaceObject
                acadObj
                "AecX.AecScheduleApplication.7.0"   ; for AutoCAD MEP 2013
 propSets (vlax-invoke-method schedApp 'PropertySets vlaObj)
 psdName "MvPartCustom_TypeStyles"
 propSet (vlax-invoke-method propSets 'Item psdName)
 properties (vlax-get-property propSet 'Properties)
propNameValList (reverse
(vlax-for prop properties
  (setq propNameValList
    (cons
      (cons
        (vlax-get-property prop 'Name)
        (vlax-variant-value
          (vlax-get-property prop 'Value)
      propNameValList
What if you get the Style Object (StyleObj) and look for propsets on that instead of the selected object?
I tried on my end and I was able to get the style based prop set list.
Chris
StyleObj (vlax-get vlaObj 'Style);<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<<Modified
                acadObj
propSets (vlax-invoke-method schedApp 'PropertySets StyleObj);<<<<<<<<Modified
    (cons
      (cons
        (vlax-variant-value
      propNameValList
Valued Contributor
Chris.Picklesimer
Message 2 of 3 (431 Views)
Re: Acces Property Data this works but...
02-06-2013 11:13 AM in reply to: mdhutchinson
Chris
                acadObj
    (cons
      (cons
        (vlax-variant-value
      propNameValList
Valued Mentor
mdhutchinson
Message 3 of 3 (422 Views)
02-07-2013 08:22 AM in reply to: Chris.Picklesimer
That works. Thanks!
