AutoCAD Architecture Customization
Welcome to Autodesk’s AutoCAD Architecture Customization Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture Customization topics.
ACA 2015 - Plotter Manager fail
4 REPLIES 4
Spaup20
1108 Views, 4 Replies
I'm trying to set up my plotter in ACA 2015, which is a HP Designjet 1050c on windows 8.1 pro. I click on add a plotter wizard and get to the edit plotter configuration screen just fine. When I click the custom properties button I get the following error, "Function address 0x810356 caused a protection fault (exception code 0xc0000005)."
"The application Property sheet pages may not function properly"
I have not had any problems setting up any of our other printers in our office other than this one. I have both x64 and x86 drivers installed.
Any help on fixing this problem ASAP would be appreciated.
4 REPLIES 4
in reply to: Spaup20
Hi
i have the same problem
hp1050c w8.1 autocad 2015
the 1050c is not compatible with w8.1
Smiley Mad
http://www.cadstudio.cz/en/hp-designjet-compatibility-with-windows-8-art1755
Spaup20
We have ACA 2014 on our windows 8.1 pro computers and our 1050c works fine with that so your comment doesn't hold water!  It's obviously an Autocad problem not a windows problem.
yes autocad problem !!!
You can try the HP Z6200 driver -  it is ok at 90 % Smiley Happy
”Boost
