I wish that xrefs could be attached to template (dwt) files using relative path.
When using the Project Navigator and setting up a template for a title sheet we have the project information in the template as fields and the title sheet layout (lines etc.) as a block within the template. If we have the layout (lines etc.) as an xref attached to the template file it only works when using the full path option which becomes a nuisance when archiving the project.
