Attached I have a dwg of typical van accessible ada stalls. Depending on which area I select to hatch the no parking striping, autocad will spit out a warning. I have marked the warning areas in a cloud (delete cloud before hatching). I double checked all the z planes, audited, purged regs, and even converted all the linework joined plines.
My problem with this is if autocad errors, i have to go through and double check all my intersections and repeatedly try hatching random locations in hope that autocad will not glitch. Seems like everyday is a new glitch in 2013.
I have taken a look at this supplied file to further test the hatch functionality. In this case I have taken your file, inserted it into a new blank file and then ran the similar cleanup as you have described. Once this was done the file then responded favorable to hatch in all areas. I have attached the new file for testing. Please test this file and verify functionality is restored. Thank you and we look forward to your reply update.
Videowith file: http://screencast.com/t/cdiDhZks
