rhino rules wrote:
> I used to have an xref button in the lower right hand corner of my display - I think in the tray. I could click on it and reload all xrefs. I just noticed that it is missing and I cannot figure out how to turn it back on. Can someone help?
Well, it only shows up when you have a DWG loaded with xref's.
Did you perhaps turn your drawing status bar off (Options, Display tab)
if so it moved this down to the main windows status bar (lower, lower right)
Also, it will hide itself if you turned off "Display Icons from
services" from the main status bar (see attached image).
David Kurtz
