Not sure where the wish lists went, but here are two items:
1. The ability to use symbols in Schedules (i.e. door & window tags) - to be more specific: the ability to use the MVBs.
2. A screened door assembly? (main door swings in; screened door swings out)
Solved by David_W_Koch. Go to Solution.
David, That's perfect for a single door. What about a double door, with a double screen door?
Unfortunately, there is no Double Communicating door type. There are also the Single-Dhung and Double-Dhung types, but these are really meant for double-acting doors, and only show one door panel, with a swing that goes on both sides.
You would have to start with a Double and add custom block(s) to represent the screen doors if you want a panel shown on both sides.
To add to the wish list, some might be an easier fix than others:
1. Allow keyboard shortcut for all commands. i.e. Systems>Lighting Device
2. The ability to tag data from non-primary connectors. (i.e. if an electrical device has 2 electrical connectors)
3. The ability to copy/monitor all model family category types.
4. Compatibility with .SHX font type
Welcome to the community!
Are these AutoCAD Architecture wishes or Revit MEP wishes? You may want to start a new thread in the Revit MEP forum if you want Revit MEP users and/or development team to see these. Or, if you can get there before 6:00 pm US Pacific Time today (October 7, 2015), post to the Revit Answer Day forum.
