Whoa! Hey I did not mean to upset you... I just feel even with a 3 or 4 component wall, once the body modifier is in place it is pretty easy to move around and manipulate- but you are right there are a couple of extra steps up front, and if you do not plan to change the window- a simple opening would be great (our clients are always changing items, so I try to prepare for that). And I would also agree that for small projects like houses, one file drawings are appropriate. I work on larger commercial projects and need each floor seperate for the other disciplines to do there work, electrical, mechanical, etc... Point is, I guess there are a number of different ways to to achieve the same end result!
SMILES
