I want to add a window that has a sloping sill, like you might find in a 2nd floor wall near a first floor roof.
I didn't see any ACA types like this.
Surely someone has made a similar, what would be the best way.
Thanks ...
Solved by dbroad. Go to Solution.
If you mean a window sill that slopes from left to right rather than from inside to outside, then
Draw an outline of what you want (closed polyline). Convert the polyline to a profile. Create a new window style and use that profile instead of a rectangle.
