Hi ~
I have Architecture 2009 and my computer needed to have my profile rebuilt. Now I am unable to tile my acad drawing horizontally or verically like I used too. I tried to rebuilt the file and reinstall but that doesn't seem to work. Also rather than opening at least 2 drawing (or more) now results in seperate sessions rather than 1 session with 2 or more files. Anyone have any suggestions as to what the setting is that I need to update?
Solved by bgempp. Go to Solution.
Solved by pendean. Go to Solution.
Sounds like someone reassigned your DWG application to ACAD.EXE instead of the default ACLAUNCHER in Windows Explorer: what else got "rebuilt" other than your profile?
To Dean ~
The dwg was acttached to acad.exe so I reattached all dwgs to ACLAUNCHER as you suggested. I still am unable to tile my autocad darwings Horizontally or Vertically but I am now able to open mutiple drawings in 1 session of Autocad. Thanks for solving part of the problem. Now how about the other part of tiling my autocad drawings Horizontally or Vertically. Should I restart my computer? Just for your information, I have a 64 bit machine operating on Windows 7 with 12 gig of ram and a ATI Firepro V8700 video card. Again, many thanks
I've never experienced that issue before: if you load a stock or new PROFILE instead of your rebuilt one, does the problem go away?
I believe there is a command 'SDI' that sets up AutoCAD to only allow 1 drawing per session. Set it to <0> to allow multiple drawings per session.
