AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
window tags are not in sequence
1 REPLY 1
Nutecgroup
150 Views, 1 Reply
when using the window tags, this is what I'm doing:
1. select the window tag from the callout pallet
2. select the windon to start tagging
3. at the Edit Property Set Data, i change the number to start with at 100
4. next, I use the Multiple option and window select the entire floor plan
5. at the prompt to re-tag, i click no
6. at the next Edit Property Set Data, i click ok
but the tags are not in sequence. What am I doing wrong?
1 REPLY 1
in reply to: Nutecgroup
Nothing, other than expecting ACD-A to know what your sequence is. Either tag the windows, one-by-one, in order, or do what you are doing and then use the renumbering tool to get the numbers in the order you want.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
”Boost
