AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Window Muntin Profiles
3 REPLIES 3
VaDesigner10
458 Views, 3 Replies
Is there a way to give the muntins in a Muntin block a profile?
3 REPLIES 3
dbroad
in reply to: VaDesigner10
No.  I'm kind of glad though.  How would you use that capability?  Seems like it would make the model needlessly complicated for the few times an accurate detail (3/4"=1'-0" or larger) would need to be drawn.
Architect, Registered NC, VA, SC, & GA.
John.W.Mumaw
in reply to: dbroad
Of couse if you bypass the muntin blocks that are available on the muntins tab and add your blocks on the other tab (which you would need to do anyway if the muntin pattern you wanted wasn't available on the muntins tab), you can make the muntin block as complicated as you want.
But as Doug pointed out, unless you need this for rendering or detailing, it would unnecessarily clutter your drawing.
John
John W. Mumaw
Timber Frame Designer
Lost Bent Woodworking & Design
VaDesigner10
in reply to: John.W.Mumaw
That seems to work. Of course what some call clutter, others might consider necessary depending on the level of design and detailing the project may require. Thank you.
”Boost
