Is there a way to give the muntins in a Muntin block a profile?
Solved by John.W.Mumaw. Go to Solution.
No. I'm kind of glad though. How would you use that capability? Seems like it would make the model needlessly complicated for the few times an accurate detail (3/4"=1'-0" or larger) would need to be drawn.
Of couse if you bypass the muntin blocks that are available on the muntins tab and add your blocks on the other tab (which you would need to do anyway if the muntin pattern you wanted wasn't available on the muntins tab), you can make the muntin block as complicated as you want.
But as Doug pointed out, unless you need this for rendering or detailing, it would unnecessarily clutter your drawing.
John
