I am working with window schedules. I have a situation where I have a 4'6" tall dormer wall, with the bottom of the wall set at an elevation of 7'-0". I have windows in the dormer wall, with the window head height set at -6" from the top of the wall. When I create my schedule, the head height property data is relative to the anchoring object, and the schedule reports the window head height at 4'-0". The true head height of the window is 7'-0" + 4'-0" = 11'-0".
How can I get my schedule to report the true head height of the window, not the head height relative to the anchoring wall?
Thanks.
Solved by John.W.Mumaw. Go to Solution.
The simplest way would be to draw the dormer wall with a baseline of Z=0 and then edit the bottom of the wall (not the baseline) to have it at 4'-0". That should get things reporting correctly. If that's not practical for some reason you could edit your property set to have the reporting field either report the actual head height or a manual override from a third field.
John
