Is it possible to get the clear opening dimensions into a window schedule?
I understand how to modify the schedule but am not having any success figuring out which pieces of data to select.
I'm using ACA 2014.
Do you have a property attached to your Windows that holds the clear opening value? Do you measure the Window Width to the outside or the inside of the frame? If you measure to the outside, then the Width and RoughWidth properties will have the same value. If you measure to the inside, then the RoughWidth property will be equal to the Width plus two times the FrameWidth.
I assume that your clear opening dimension includes the out-to-out dimension of the frame plus an allowance on each side. In that case, you would need to add a real-type manual property to hold the allowance (either total, or on one side) and a formula property to add the allowance (twice the allowance if the value is for just one side) to the RoughWidth. Then add the formula property as a column to your Schedule Table Style.
