AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wide polyline shows as lines
6 REPLIES 6
1754 Views, 6 Replies
Hi. I'm using a block with thick polylines. When i copy it to another drawing the thickness does'nt show anymore, only the contours drawn in thin lines.
How do I get my wide polylines to show correctly? Is there a setting I should know about?
I'm attaching an image of the block the way it should look, and one of how it looks when I paste it in drawning no 2.
Thank you,
/a172
6 REPLIES 6
pendean
A layer turned off/frozen perhaps?
Or LWEIGHT setting bylayer is different between the two files?
David_W_Koch
Is FILLMODE set to 0?  If so, set it to 1 and regenerate the drawing.  (You can also use the FILL command, and choose the ON option.  You will still need to regenerate the drawing to see the change.)
David Koch
AutoCAD Architecture and Revit User
Blog | LinkedIn
FILLMODE and FILL are set to 1 in both drawings.
David_W_Koch
Are you viewing in 2D Wireframe?
David Koch
Blog | LinkedIn
David_Knight
in reply to: David_W_Koch
check your USC.
usc -> world
looks like it might be rotated a hair (like 0.1%) had it happen when i drag my middle mouse a hair by mistake.
Go to View tab and change your view to 2d Wirefame.
You must be on 3D Wireframe
”Boost
