Sure, ACA 2008
"archie456" escreveu na notícia da
mensagem:5999655@discussion.autodesk.com...
> Thanks for your replies chaps;
> Fernando Morais - Are you sure your not using AutoCAD 2009??
> klompje - Your using AutoCAD 2009 thats why it works.
> The reason it works in AutoCAD 2009 is that one of the new features of
> 2009 is that wall with different base heights clean up - this doesn't fix
> the problem, it just hides it.
> Unfortunatly we are using 2008...
> BUT!!!!
> The winner is eviele!!
> That LISP program worked a treat!
> I still don't know how it is possible to draw a wall with different Z and
> levels at each end - and they all have the same UCS.
> This seems like a bug to me - but your LISP worked perfectly!
> Thanks - this has really been bugging me!
