in paper mode
the space outside space is white in color
and i can not find the way to change it into black and can not change it in option-->drafting
Solved by ToanDN. Go to Solution.
Try Options-Display colors Sheet layout. You can set to any color you like.
In addition to the above comment, uncheck the [Display paper background] also under Options/Display/Layout elements.
