AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Where would I find Tool Palette Group info stored at?
2 REPLIES 2
Jason_S
1122 Views, 2 Replies
I have some tool palette groups that I would like to share with all users but can't seem to find where they are stored at. Creating a Profile didn't work. Looking in the CUIX file and can' seem to find it there.
Thanks for the help.
2 REPLIES 2
in reply to: Jason_S
copy the profile.aws files from 3 locations on your computer to the 3
locations on the other computers
C:\Documents and Settings\user name\Application Data\Autodesk\ACA
2010\enu\Support\Profiles
2010\enu\Support\Profiles\AutoCAD Architecture (US Imperial)
2010\enu\Support\Profiles\Unnamed Profile
wrote in message news:6390913@discussion.autodesk.com...
brentcole3410
Just ran into same problem trying to transfer numerous new profiles with tool palette groups to numerous workstations.  We did this:
 Create your profiles with tool palettes and associated groups.  Export your profile for safety.  Find your profile group storage files under your local user directory  %USERPROFILE%\appdata\roaming\autodesk\autocad mechanical 2012\r18.2\enu\support\profiles\
Copy the all of these folders and associated *.AWS files inside.  Place all of these folders on a network drive.
Find "Autodesk/Autocad/.........../Profiles/" in your registery.  In registery look under EACH "Profile" folder and find "General" folder.  Find PROFILESTORAGE  and edit & change the path shown to your network drive.
You will then have to get a little more involved and write a program or BAT file to copy the Creator's autocad registery and launch them over the network to the desired workstion.
As a backup, when I create an individual tool palette structured into groups I use the tool palette customization option and "Export All" and save the tool palette group as CLIENT.XPG.  This enables me to add a new tool palette & group without necessarily messing with a profile.
”Boost
