I need to download more residential wall types for the design center tool palette. For example I need a smart wall that consist of 7.625" concrete foundation wall with real field stone veneer. How and where do I go to find and download more wall types for autodesk architecture 2013?
When ACA 2013 was installed, was one or more localized content packages specified (beyond the intial default "Global" content)? New to 2013, the global content is fairly limited (keeping the download size smaller) and you would want to have the appropriate content for the region in which you practice installed to provide a broader range of out-of-the-box content.
That said, the out-of-the-box content will not have a style for every conceivable need. You can search the Internet for content (there is an AutoCAD Architecture Content Discussion Group here, meant for sharing content with others; the AUGI Forums have a similar forum as well), but you may have to create your own Wall Style and make your own Tool palette tool to insert it. Starting with a Wall Style that is similar and editing that may make the task easier.
