Dear all
How can I have an exterior wall face with multiple finishes at different angles?
Solved by David_W_Koch. Go to Solution.
Hi Ace Ali,
As an initial suggestion, you might want to create a Wall Style for each different variation.
Here is a link to get you started: About Wall Styles
Let me know if that helps, and have a great weekend!
I have a similar question I have an exterior wall 10m long. I want to add a 2m finish midway along the wall. Should I break the wall and use a different wall style to show the 2m finish? lastly, if i want to show a finish in a circle on a portion 0f my 10m long wall, how do i do this? plz view attachment.
Many thanks for your reply
Let's say that I wanted to paint a wall with 2 different colors at an angle, is there any way of doing so?
thanks again
I am not clear on what you are trying to do. For the first case, are you saying your 10 m long exterior wall has one finish, bottom to top, for the first 4 m, then 2 m of a different finish bottom to top, and finally 4 m of the original finish bottom to top. If so, then three separate Wall segments, using two different Wall Styles would likely be the way I would approach this.
If, on the other hand, you are saying your Wall has one finish from the bottom up to a certain height, then a 2 m horizontal band of a different finish material, and then the original finish material resumes from the top of the 2 m band to the top of the Wall, that can be done with one Wall Style, by stacking three components at the exterior face of your Wall, and setting the top and bottom of each component to match your specifications within the Wall Style.
As for a feature finish in a circle at some point along your Wall, you will not be able to do that easily as a component of the Wall. You may be better off modeling this separately, perhaps with a Mass Element.
