I have a wall tool whose style has a sweep attached, when I added the tool to the palette it drops the sweep. I know this was a wish list item a few years back. Has the feature been added that allows me to add the sweep to the tool so I dont have to manually import and add the sweep in every drawing? Or does anyone know a workaround while Autodesk figures this one our?
No.
I use a wall style for my gutter/eaves and the gutter uses a sweep.
In my library file I created a block containing a length (or two) with the sweep.
I then added the block to my pallete and set it to explode on insert.
Then I just select it and right click for 'add selected' and you know the sweep comes with it.
Delete the inserted exploded block.
I'm afraid It was a wish list item for about 10 years! Autodesk team, please add this option! We miss it a lot!
