Greetings-
ACA 2011
Last night I was drawing in a View of the Floor Plan. The Floor Plan Construct is in the drawing and I've been dimensioning the drawing. OSNAP is on and I would dimension from corner to corner, etc., and everything was normal. Halfway done I went to sleep for the night and turned off the computer.
This morning I can't snap to the walls...at all. I can snap to the windows, the countertops, the doors, anything in the floor plan construct I want...EXCEPT the walls themselves. Is there a keystroke that toggles this that I may have hit last night or this morning inadvertantly? If not, I have gremlins.
Scott
Solved by David_W_Koch. Go to Solution.
Hello Scott,
perhaps you have gremlins
There is an OSNAP-Option but this is only for drawing walls and place the OSNAP to the baseline of the wall.
No other option.
How far is your drawing from 0,0,0? Sometimes the great distance make problems.
Other reason... The Hardware-Acceleration of the graphic-card. Is it active?
In our OSNAP settings, Is the option "Allow General Object Snap Settings to act upon wall justification line" checked? If so, uncheck. If it's checked, you cannot grip edit to wall mid and enpoints.
Make sure Layer 0 is on and thawed (and, if working through a viewport, VPLAYER thawed). While you are at it, check the Defpoints layer, too. If you map the visible components of your Walls to a layer or layers other than 0 or the parent Wall's layer, make sure those are not off, frozen or VPLAYER frozen as well.
