I have no idea how easy or hard implementing that would be from a programming standpoint, but you would still need to go through the file after such a mass change to fix all of the cleanup issues that will likely result from moving the justification lines without moving the walls. That said, there are times when I wish I could change the justification of many walls at once without moving them, too. (Even when done manually, you need to make adjustments to cleanups.)
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
