The wall icon is not on my ribbon or tool palettes. I don't have the build panel under home so I don't know how to get the icon to show up?
Also having a problem when draw the wall it comes in to thick. How can you get it come in at 5 1/2" every time. Windows and doors are also coming in to large.
Thank you.
@danielle.mikolay wrote:
1. The wall icon is not on my ribbon or tool palettes. I don't have the build panel under home so I don't know how to get the icon to show up?
2. Also having a problem when draw the wall it comes in to thick. How can you get it come in at 5 1/2" every time.
3. Windows and doors are also coming in to large.
Thank you.
Hello and welcome to the forums,
Somehow the panel was removed from the profile and workspace then. The easiest way to get it back is to reset AutoCAD Architecture back to its default settings. Please note that this will remove all customization. Exit ACA, From the Windows start menu->All programs->Autodesk->Autocad Architecture 20XX->pick the Reset Settings to Default tool. This tool is only available for versions 2012 and above. Let us know if you have a lower version.
