AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
wall displays when plotting
2 REPLIES 2
saturn99
147 Views, 2 Replies
i would like to plot only the outlines of my walls. I do not wish all the layers that composed the walls, such as gyp.bd, airspace etc...I ONLY WANT THE TWO OUTER LINES.
ANY HELP WILL BE APPRECIATE IT....
THANKS LOTS
2 REPLIES 2
in reply to: saturn99
Either turn off the display of all Wall components but the Shrink Wrap in the active Display Represenation(s) for the active Display Representation Set (based on the Display Configuration and view direction you choose before plotting) - to remove the inner lines and hatches from both the screen and your plot - or assign those components to a non-plotting layer.
David Koch
Autodesk Discussion Group Facilitator
Using ADT 2004 at work; access to 2005, 2006, 2007 & 2008 at home
saturn99
Thank you very much.
”Boost
