1.) I have set up my stud walls to display in the High Detail config as
they would actually be constructed. That is, if I have an intersection
between a rated wall and a non-rated wall, the non-rated wall (even the stud
component) stops at the gypsum board of the rated wall. I need to show just
the stud component in Medium Detail, but the problem is that at this type of
intersection, there is a gap between studs where the gyp is turned off.
Using shrikwrap is not an option, I have to show just the stud. Is there
any way to get the studs to meet?
2.) Since I would like to show the line of my header in these walls, is
there any way to view just the line of the stud component above? Currently
it is showing the outer edge, which is unacceptable.
Thanks.
"ADT3 is a big improvement, but it seems to want us all to be Matt Dillon."
Bob Kellerman, 2001
