AutoCAD Architecture Forum
Welcome to Autodesk’s AutoCAD Architecture Forums. Share your knowledge, ask questions, and explore popular AutoCAD Architecture topics.
Wall component won't update
2 REPLIES 2
TexShalter
295 Views, 2 Replies
I am somewhat new to ACA so please be forgiving ...
I've got a wall style that has multiple components. I have changed one component so the bottom starts 12" below the baseline ht of the wall.
The section window display reflects the change, but the wall style won't update.
Is there a setting I'm missiong somewhere.
2 REPLIES 2
KathyMoffa
in reply to: TexShalter
Even though you indicate in the wall style that a component is to start below the baseline, you still have to manually project it down.  Right click your wall, select Roof/Floor line, select Floor and Offset -12.  If all your components project down, not just the one component, make certain that the other components' Bottom Elevation is set at Baseline, not Wall Bottom.
TexShalter
in reply to: KathyMoffa
That's it. thanks Kathy
 Seems like it should do it automatically, though
”Boost
